#359082 - 29/06/2013 23:11 "Cloud" based file synch / backup?
Hi, I have yet another q...
I'm looking for an online file synch / storage service like dropbox or box.com, but I want the synched files to be under c:/user. Unfortunately, both of those services require that the synched directory be on the desktop with the associated 100 character long path. I already have, occasionally, problems with path length.
So, since the files I deal with are large, I can't go with an all-online service like google docs. I need all the files stored locally and automatically uploaded to the service when they are created or changed. Also, I have a couple of engineers working with me and those files need to be automatically updated on their drives as well.
Does anyone have any experience with this sort of thing?
Thanks!
#359083 - 29/06/2013 23:45 Re: "Cloud" based file synch / backup? [Re: larry818]
robricc
aerofs sounds like it might be the thing, but I have no experience with it. I've been on the waiting list for months.
#359084 - 30/06/2013 00:22 Re: "Cloud" based file synch / backup? [Re: robricc]
You can move the Dropbox path wherever you like. Dropbox doesn't default to the Desktop either. It's normal location on a regular Windows 7 machine is "C:\Users\<username>\Dropbox"
I have another machine (carpc) with an entire drive D:\ as the Dropbox store (selectively taking parts of the above Dropbox store)
#359085 - 30/06/2013 02:42 Re: "Cloud" based file synch / backup? [Re: robricc]
This interests me actually. I'd prefer to not have the dependency on a cloud and be able to run this on my NAS.
Waiting list? You can sign up and download now. Does it not work?
#359088 - 30/06/2013 12:04 Re: "Cloud" based file synch / backup? [Re: Shonky]
robricc
That's weird. I was on a waiting list for an invite. It seems it may be open now. It would have been nice if they notified me.
#359091 - 30/06/2013 17:49 Re: "Cloud" based file synch / backup? [Re: robricc]
If you want good sync between computers, without the cloud piece in the middle acting as another copy, try btsync.
I've been very impressed with it so far. Can always stash a cloud copy on an Amazon EC2 instance or similar if that part is needed too.
#359092 - 30/06/2013 19:46 Re: "Cloud" based file synch / backup? [Re: larry818]
I think Rob's suggestion is the most appropriate, so I'll just mention two things.
First, Google Docs is called Google Drive now, and it's not all-online. It can have that option, but it can also work entirely like Dropbox if you want it to.
Second, as others have mentioned, your Dropbox folder can be anywhere you want it to be located. Going even further, you don't even have to move the Dropbox folder. In the past I've used symbolic links in Windows to make Dropbox back up folders that weren't really located in the Dropbox folder. You could then create a folder in your root C: drive and make Dropbox think it's also located inside it's own folder. That should get around the character length limit...
#359093 - 01/07/2013 01:18 Re: "Cloud" based file synch / backup? [Re: robricc]
I installed it and it's up and running. Not sure I'll continue to use it, but I like it. Dropbox does work fairly well for me though and I do have a large chunk of space which I don't have to pay for (about 18GB now plus 50GB worth of SGS III bonus).
